    Zapier Instructions
    Instructions
      Connect TRIGGERcmd to hundreds of other TRIGGERcmds with Zapier
      Zapier lets you connect TRIGGERcmd to 1,000+ other web services. Automated connections called Zaps, set up in minutes with no coding, can automate your day-to-day tasks and build workflows between apps that otherwise wouldn't be possible.
      Each Zap has one app as the Trigger, which causes an Action in other apps like TRIGGERcmd.
      Getting Started with Zapier
      Sign up for a free Zapier account, from there you can jump right in. To help you hit the ground running, here are some popular pre-made Zaps.
      How do I connect TRIGGERcmd to Zapier?
      Log in to your Zapier account or create a new account.
      Navigate to "Connected Accounts" from the top menu bar.
      Now click on "Connect new account" and search for "TRIGGERcmd"
      Use your credentials to connect your TRIGGERcmd account to Zapier.
      Once that's done you can start creating an automation! Use a pre-made Zap or create your own with the Zap Editor. Creating a Zap requires no coding knowledge and you'll be walked step-by-step through the setup.
      Need inspiration? See everything that's possible with TRIGGERcmd and Zapier.
