    CLAUDE.md to use local AI model
    1.4k
      I just followed this guy's tutorial:
      https://towardsdatascience.com/run-claude-code-for-free-with-local-and-cloud-models-from-ollama/
      I'm using claude code with ollama running gpt-oss:20b on my PC with my Nvidia GPU to speed it up.
      I found this CLAUDE.md file works well. It tells the gpt-oss model how to use the Write tool to write to files:
      My CLAUDE.md file:
      ## Important rules
      - If the user wants you to write a file, do it. Use your Write tool to create the file. The Write tool has a required parameter called "file_path".
      My interactive claude session:
       ▐▛███▜▌   Claude Code v2.1.29
      ▝▜█████▛▘  gpt-oss:20b · API Usage Billing
        ▘▘ ▝▝    ~/appdev/raspi
        /model to try Opus 4.5
      ❯ create a python script called hello.py in the current directory that prints "Hello World".
      ● Write(hello.py)
        ⎿  Wrote 2 lines to hello.py
            1 print("Hello World")
      This is a command that runs a non-interactive claude session. You could run it via the TRIGGERcmd agent
      claude -p -d --model gpt-oss:20b --permission-mode acceptEdits "create a python script called hello.py in the current directory that prints Hello World"
      I created a this myclaude.bat file:
      set ANTHROPIC_BASE_URL=http://127.0.0.1:11434
      set ANTHROPIC_AUTH_TOKEN=ollama
      cd c:\myfolder
      claude -p -d --model gpt-oss:20b --permission-mode acceptEdits %1
      My Command field in the GUI editor looks like this:
      start /w c:\myfolder\myclaude.bat
      My commands.json entry looks like this:
        "trigger": "claude code",
        "command": "start /w c:\\myfolder\\myclaude.bat",
        "offCommand": "",
        "ground": "foreground",
        "voice": "",
        "voiceReply": "",
        "allowParams": "true",
        "quoteParams": "true",
        "mcpToolDescription": ""
