    Operation on VMware virtual PCs
    2 Posts 2 Posters 566 Views 1 Watching
    • H Offline
      hondaru2004
      If a master PC VM is created and then copied and deployed, it seems that all PCs have the same computer ID, causing conflicts and preventing them from working correctly. For example, with TriggerCMD, it appears to only refer to the commands of the PC where it was started last, and it doesn’t work on all VMs. Is there any workaround for this?
        Russ @hondaru2004
        @hondaru2004, here's a powershell script that will create a new computer in your TRIGGERcmd account. It assumes you installed the agent on the master PC you cloned because it uses the token.tkn file from that install for authentication. It writes the computer ID and computer name to the config files in the user's home directory. I hope this helps.
        # === Configuration ===
        $urlprefix = "https://triggercmd.com"
        $computername = $env:COMPUTERNAME
        # Read token from TRIGGERcmd token file
        $tokenPath = Join-Path $env:USERPROFILE ".TRIGGERcmdData\token.tkn"
        if (Test-Path $tokenPath) {
            $token = Get-Content $tokenPath -Raw | ForEach-Object { $_.Trim() }
            Write-Host "Token loaded from: $tokenPath" -ForegroundColor Green
        } else {
            Write-Host "Error: Token file not found at $tokenPath" -ForegroundColor Red
            Read-Host "Press Enter to exit"
            exit 1
        # === Perform the POST request ===
        Write-Host "Making API request..." -ForegroundColor Green
        $headers = @{
            "Authorization" = "Bearer $token"
            "Content-Type" = "application/x-www-form-urlencoded"
        $body = "name=$computername"
        try {
            $response = Invoke-RestMethod -Uri "$urlprefix/api/computer/save" -Method POST -Headers $headers -Body $body
            # === Display the full response ===
            Write-Host "`nAPI Response:" -ForegroundColor Yellow
            $response | ConvertTo-Json -Depth 10 | Write-Host
            # === Extract and save the ID ===
            $computerId = $response.data.id
            if ($computerId) {
                # Save ID to TRIGGERcmd config file
                $computerIdPath = Join-Path $env:USERPROFILE ".TRIGGERcmdData\computerid.cfg"
                $computerNamePath = Join-Path $env:USERPROFILE ".TRIGGERcmdData\computername.cfg"
                # Ensure the directory exists
                $triggerCmdDir = Split-Path $computerIdPath -Parent
                if (!(Test-Path $triggerCmdDir)) {
                    New-Item -ItemType Directory -Path $triggerCmdDir -Force | Out-Null
                # Save ID to file
                $computerId | Out-File -FilePath $computerIdPath -Encoding ASCII -NoNewline
                # Save computer name to file
                $computername | Out-File -FilePath $computerNamePath -Encoding ASCII -NoNewline
                Write-Host "`nExtracted ID: $computerId" -ForegroundColor Cyan
                Write-Host "ID saved to: $computerIdPath" -ForegroundColor Green
                Write-Host "Computer name saved to: $computerNamePath" -ForegroundColor Green
            } else {
                Write-Host "`nError: Could not find ID in response" -ForegroundColor Red
        } catch {
            Write-Host "`nError making API request:" -ForegroundColor Red
            Write-Host $_.Exception.Message -ForegroundColor Red
        Write-Host "`nRequest completed." -ForegroundColor Green
        Run the script with a command like this:
        powershell -ExecutionPolicy Bypass -File .\change_tcmd_id.ps1
        Or, you could just delete the computerid.cfg file and it will prompt you for the token like when you first install the agent.
        With your input, this post could be even better đź’—
