Command ran with error code 1 trying shutdown command
I can't get the command Shutdown to work, it returns error code 1 when I trigger it in the website or Alexa.
@vitormbn , if you run the same command from a CMD window does it work? Error code 1 means it's running the command but it's failing. Ideally it will fail in the same way so you can see the error. One possible reason for the failure might be you don't have admin access on your machine.
