    TriggerCMD throws an Application Error upon computer shutdown.
    • Paul KellyP
      Paul Kelly
      Why is this happening?
      Clicking either ok or cancel allows shutdown to continue, but it is annoying. I can send/post the debug info to help with troubleshooting, but I don't know where it is.
        Russ @Paul Kelly
        @Paul-Kelly , thanks for reporting it. I'll look into it this weekend. Are you running the latest version?
        Paul KellyP 1 Reply Last reply Reply Quote 0
        • Paul KellyP
          Paul Kelly @Russ
          @Russ said in TriggerCMD throws an Application Error upon computer shutdown.:
          reporting
          TriggerCMD Version 1.0.45
          Windows 10 Pro 22H2, build 19045.5608
            Russ @Paul Kelly
            @Paul-Kelly, please upgrade to the new version (1.0.46) I just published. I wasn't able to reproduce the error, but it's an intermittent problem, so I'm not sure this will fix it. Please let me know if you see it again after you upgrade.
            • Paul KellyP
              Paul Kelly @Russ
              @Russ Done. Will keep you in the loop.
              Thank you!
