    running .jar
    • steef van der PoelS
      steef van der Poel
      i am attempting to run a .jar file remotely. I want this to be a server that's online 24/7 or at least that i have the ability to re-activate if it crashes or something similar. it appears not to be running the .jar files. i have this filled in in the command: "C:\Users\steef\Desktop\minecraftServer\minecraft_server.1.21.4.jar"
      runs on foreground
      voice: "minecraft server"
      no voice reply,
      no parameters allowed
      however it won't run. It does run from cmd line, but it doesn't start from this. I'm assuming i missed something.
      V 1 Reply Last reply Reply Quote 0
      • V
        ve1ikan @steef van der Poel
        @steef-van-der-Poel If you want to run a .jar executable, you need to run it using java. This is best done with a batch script like the following file:
        Batch Script (launch.bat)
        cd C:\Users\steef\Desktop\minecraftServer
        java -Xmx1024M -Xms1024M -jar minecraft_server.1.21.4.jar > log.txt 2>&1
        Your TriggerCMD command would have to be executing the .bat file
        Something like this would work, the command comes from Minecraft's site:
        https://www.minecraft.net/en-us/download/server
