    Alexa keeps saying "no result" when using the conversational skill
    • T
      tigor
      Hello,
      I'm trying to make Alexa say the result of a command but she keeps saying "no result" for {{result}}. I managed to have my command run (not easy, using the Custom Action to trigger a command is quite inconsistent, so I had to set up fancy activation words). I reduced my command to the simplest I could think of. It's basically a batch file that runs:
      ...\.TRIGGERcmdData\sendresult.bat "hello"
      I also checked the logs of sendresult.bat, and they seem to indicate that the result is sent correctly:
      {"data":[{"name":"...","voice":"tagada","voiceReply":"{{result}}","allowParams":false,"user":"...","computer":"...","switch_is_on":false,"runCount":3,"createdAt":"2024-12-07T20:04:37.550Z","updatedAt":"2024-12-07T20:14:43.334Z","lastResult":"hello","id":"6754aa5536561400146ee0ad"}],"message":"Command result updated successfully."}
      Could it be a timing issue? The command runs quickly (easily under 1 second), I checked in a command prompt. Any help would be appreciated!
        Russ @tigor
        @tigor, thank you for reporting this. I was able to reproduce the issue.
        I fixed it just now. Please try again.
        T 1 Reply Last reply Reply Quote 0
        • T
          tigor @Russ
          @Russ Works now, thank you so much! Also, wanted to let you know that what you do is pretty awesome. Keep it up!
            Russ @tigor
            Thanks @tigor
