New user Questioni cant paste the Token into the sign in box
Question for the life of me i cant paste the Token into the sign in Box im using a windows 10 PC and trying to type the token into the sign in box is not possible as it not possible to figure out or distinguish between a capital i or a lower case L as you can see they look the same Il
Did you try clicking the Token field, and using CTRL-V to paste it?
The Paste option in the pulldown was broken. I fixed it, so if you upgrade it should work even with the Paste option on the pulldown menu.
cheers for the reply i managed to get it pasted and working with GH but iam having an issue with smartthings where ive got it installed but keep getting an error message when ever i try to create a switch using the smartthings app. ive read that this can happen when things are out of sync, but nothing has been added to smartthings as the error message happens every time. i have deleted the smart app from both the smarrthings app and the IDE but still get the same error message ever time. any suggestions
@jay-dee, can you confirm you installed both the SmartApp and the Device Handler in the SmartThings IDE?
thanks again for the help. i didnt install the device handler it now full working. brilliant work and i have subscribed
Awesome @jay-dee! Thanks for the subscription too.
R Russ moved this topic from Announcements on
