    Boa tarde nao consigo add token para login
    4 Posts 2 Posters 871 Views 1 Watching
    • Michell LaureanoM Offline
      Michell Laureano
      Adicionei o token e nao faz login
        Russ @Michell Laureano
        @Michell-Laureano, it's saying:
        "Voce deve se inscrever antes de adicionar outro computador."
        That translates to: "you must sign up before adding another computer."
        You can only have 1 computer in your account if you haven't subscribed yet.
        Michell LaureanoM 1 Reply Last reply Reply Quote 0
          Michell Laureano @Russ
          @Russ said in Boa tarde nao consigo add token para login:
          eu sou inscrito ja nao consigo nem importar minhas config ja
            @Michell-Laureano, I translated, "eu sou inscrito ja nao consigo nem importar minhas config ja" as "I'm registered and I can't even import my settings anymore."
            I'm assuming you're talking about your commands. Your commands are stored in the commands.json file which is in your c:\Users\(your user)\.TRIGGERcmdData folder. You can copy that file, or use the Text Command Editor to copy the text and paste it into a different computer.
            Also you said you registered. If you mean subscribed, I looked and your account does not seem to be subscribed yet, so you can still only have 1 computer.
