    Command with parameters
    • M
      marti.ruiz
      Hello everyone!
      is it possible to do something like this?
      with this command I can print a label directly to a zebra printer.
      but i would like to be able to send files with different names.
      Thank you!
        Russ @marti.ruiz
        @marti-ruiz, the parameters you send with your trigger always get tacked on to the end of your command, so you should put that same command in a .bat file if you want the parameter where the %1 is.
        Your TRIGGERcmd command would run your .bat script like this:
        Your label.bat script contents:
        type "C:\BC\%1" > \\mycomputer.local\ZEBRA
