    Winamp visuals control panel
      Anyone still use Winamp to play .mp3 files?
      The Milkdrop visuals are still the best - for example.
      I built a TRIGGERcmd panel to control Winamp, including a set of my favorite visual "presets."
      Here's a Youtube video showing how it works.
      This is the panel:
      The "Preset Favorite" panel buttons run my winamp_preset.bat script with the letter as the parameter, and uses nircmd to press a series of buttons to pick the preset that starts with that letter.
      You can see here I copied some of my favorite presets to a folder called russ, and prefixed each one with a letter from a to h:
      This my panel JSON:
          "name": "Preset Favorite",
          "trigger": "DS | winamp preset",
          "params": "a,b,c,d,e,f,g,h"
          "name": "Next/Previous Preset",
          "trigger": "DS | winamp next/previous preset",
          "params": "previous,next"
          "name": "Volume",
          "trigger": "DS | winamp volume",
          "params": "up,down"
          "name": "Show Song Title",
          "trigger": "DS | winamp show title",
          "params": ""
          "name": "Presets List",
          "trigger": "DS | winamp preset folder",
          "params": "russ,all"
          "name": "Forward/Reverse",
          "trigger": "DS | winamp forward reverse",
          "params": "reverse,forward"
      My commands.json entries:
        "trigger": "winamp preset",
        "command": "c:\\tools\\winamp_controller.bat",
        "offCommand": "",
        "ground": "foreground",
        "voice": "",
        "voiceReply": "",
        "allowParams": "true"
        "trigger": "winamp show title",
        "command": "nircmd sendkeypress t",
        "offCommand": "",
        "voice": "",
        "voiceReply": "",
        "allowParams": "false"
        "trigger": "winamp preset folder",
        "command": "c:\\tools\\winamp_preset_folder.bat",
        "offCommand": "",
        "voice": "",
        "voiceReply": "",
        "trigger": "winamp volume",
        "command": "c:\\tools\\winamp_volume.bat",
        "offCommand": "",
        "voice": "",
        "voiceReply": "",
        "trigger": "winamp forward reverse",
        "command": "c:\\tools\\winamp_ff_rw.bat",
        "offCommand": "",
        "voice": "",
        "voiceReply": "",
        "trigger": "winamp next/previous preset",
        "command": "c:\\tools\\winamp_next_previous_preset.bat",
        "offCommand": "",
        "voice": "",
        "voiceReply": "",
      These are the .bat files in my c:\tools folder:
      winamp_ff_rw.bat
      if "%1"=="reverse" nircmd sendkeypress left
      if "%1"=="forward" nircmd sendkeypress right
      if "%1"=="next" nircmd sendkeypress spc
      if "%1"=="previous" nircmd sendkeypress backspace
      winamp_preset.bat
      nircmd sendkeypress %1
      nircmd sendkeypress enter
      nircmd sendkeypress esc
      winamp_volume.bat
      if "%1"=="+" nircmd sendkeypress up
      if "%1"=="-" nircmd sendkeypress down
      if "%1"=="up" nircmd sendkeypress up
      if "%1"=="down" nircmd sendkeypress down
      rem bring up the current presets path
      nircmd sendkeypress f8
      if "%1"=="russ" goto russ
      if "%1"=="all" goto all
      goto end
      :russ
      rem backspace for each letter in "presets"
      rem type out russ
      goto select
      :all
      rem backspace for each letter in "russ"
      rem type out presets
      nircmd sendkeypress p
      goto select
      :select
      rem press enter
      nircmd sendkeypress escape
      :end
