    Bookmark URls changing?
    2 Posts 2 Posters 992 Views 1 Watching
    • S Offline
      Smart Communities
      Just noticed the trigger URL changes every time I view the Bookmark.
      Was this always the case?
      Do the old ones ever expire?
      Is there a way to set it so it never changes?
      • RussR Online
        Russ @Smart Communities
        @Smart-Communities, good question. The normal/original bookmarks never expire unless you configure them to.
        Also yes, it has always changed when view the bookmark page because the normal bookmark URL's use a JWT, and the "iat" (issued at) timestamp value changes every time you view the page.
        If you copy/paste the JWT into the JWT reader jwt.io, it will show you the payload data like this:
        If you want a consistent bookmark URL that never changes, you should create a "Short Bookmark" using the "Create Short Bookmark" button at the bottom of the bookmark page.
        Short bookmarks look like this: https://triggercmd.com/sb?b=po3gTwiVag0pkcZ1
        To view and delete your short bookmarks, click the "Your Short Bookmarks" link on the left:
        One nice thing about short bookmarks is they continue to work even if you delete and re-create the command because it specifies a computer name and trigger name.
