    IFTTT with Google Calendar: description parameter triggering an error "Action failure message: Illegal characters in parameters"
    574
    • Thomas Vander SticheleT
      Hi,
      I'm trying out an integration where I want to pass the description of a matching calendar event to a local script, so it can parse it for an obsidian URL to open.
      in IFTTT, I ask the applet to just pass the Description as a parameter.
      The activity log shows this error: Action failure message: Illegal characters in parameters
      The description is:
      open obsidian://open?vault=main&file=4%20Archives%2FPKB%2FPeople
      So lots of potential for illegal characters there 😉 Is there a way to ask IFTTT to encode the description in a way that TriggerCMD will accept?
        Russ @Thomas Vander Stichele
        @Thomas-Vander-Stichele, you could try checking this checkbox in your user profile:
        Log into your TRIGGERcmd account, then click your name in the upper-right and click Profile to open your profile page.
        Steve LeeS Thomas Vander SticheleT 2 Replies Last reply Reply Quote 0
        • Steve LeeS
          Steve Lee @Russ
          @Russ is there a good reason this is opt in rather than always the case?
            Thomas Vander Stichele @Russ
            @Russ Thank you, that worked! Had no idea that option was there. I couldn't find it in the documentation for IFTTT - might make sense to add it?
            I also had to add double quotes in the IFTTT config around description, otherwise bash would drop everything after & when spawning the command.
              Russ @Steve Lee
              @Steve-Lee, good question. The reason those characters are blocked by default is for security. If a hacker got ahold of your account and you have those characters enabled, they could use parameters to run arbitrary commands.
              Steve LeeS 1 Reply Last reply Reply Quote 0
              • Steve LeeS
                Steve Lee @Russ
                @Russ blimey, cross site scripting vulnerability!?
                  Russ @Steve Lee
                  @Steve-Lee, no I mean if you have those characters enabled, you could put a whole command in the parameters field and run a second command, like this:
                  russ@linux:~$ echo hi & echo russ
                  [1] 72
                  russ
                  hi
                  • Steve LeeS
                    Steve Lee @Russ
                    @Russ yeah, I meant similar to XSS really - untrusted input getting passed and parsed 🙂 And no way to escape. Thanks for explanation.
                    • RussR Russ moved this topic from API on
