Shell script not running via Alexa
I created a shell file but it is only executed manually through the TRIGGER interface. When I try to run it through alexa, it is informed in the log that it was successfully executed, but the script is not executed.
system ubuntu
@José-Pábulo, please try switching the command from background to foreground, or vice versa.
The GUI Editor will run both types of commands, but the foreground agent won't run background commands, and vice versa.
Did you install the background agent?
