    issues with Starting a batch
    4 Posts 2 Posters 612 Views 1 Watching
    • Kristopher AdamsK Offline
      Kristopher Adams
      When i run my bat file from the trigger, it spams the command window with hundreds of the bat file running![alt text]
      Command: start C:\temp\curl.bat
      Bat (although looks more complex this in the picture. it has the exact same issue when ran):
      curl %1
      Param: http://localhost
        Russ @Kristopher Adams
        @Kristopher-Adams, can I see what's in your curl.bat script?
        Kristopher AdamsK 1 Reply Last reply Reply Quote 0
          Kristopher Adams @Russ
          @Russ sure here it is. btw this machine is remoted into and my phone wont let me crop it smaller.
            @Kristopher-Adams, you could try renaming your curl.bat file.
            I suspect it might be running itself because the command in the script is curl.
