    Cant install background agent
    • T
      TI_Gaming_TV
      i installed Triggercmd on by Dietpi and everything works fine, but im not able to install the background agent. My directory is root/TRIGGERcmd/src-Agent. The daemoninstall.sh is there, but im not able to install it.
      • T
        TI_Gaming_TV
        This is not existing:
        • T
          TI_Gaming_TV
          When i try this: /root/TRIGGERcmd-Agent/src/installdaemon.sh
          I get this: find: ‘/usr/*/triggercmdagent’: No such file or directory
          Failed to enable unit: Unit file triggercmdagent.service does not exist.
          Unit triggercmdagent.service could not be found.
          • T
            TI_Gaming_TV
            I changed some lines in daemoninstall.sh and it works now
              Russ @TI_Gaming_TV
              @TI_Gaming_TV good job getting it to work.
              If you don't mind sharing what you had to change, I could probably make the script more universal so it works on more OS's.
              • T
                TI_Gaming_TV
                I changed in the installdaemon.sh the code to this:
                find / root/TRIGGERcmd-Agent -type d -name "src" | grep /src | while read dname; do /root/TRIGGERcmd-Agent/src env node $dname/agent. js --daemoninstall /bin/sh $dname/daemonmqr.sh --add $HOME/ . TRIGGERcmdData
                  Russ @TI_Gaming_TV
                  Thanks @TI_Gaming_TV.
