    List your commands
    API
    1.4k
      List your commands
      import requests
      url = "https://www.triggercmd.com/api/command/list"
      # For authorization
      headers = {
          "Authorization": "Bearer <This is your token from the Instructions page. >"
      r = requests.post(url, headers=headers)
      print(r.json())
      M 1 Reply Last reply Reply Quote 0
      • M
        manuel @Russ
        @Russ no puedo iniciar sesión porque me piden el token , accedo a instrucciones para comandos token pero no funcionan. que puedo hacer. si me puedes enviar el token de activación por mensaje mejor.
          Russ @manuel
          @manuel, I translated that as, "I can't log in because they ask me for the token , I access instructions for token commands but it doesn't work. what can i do If you can send me the activation token by message better."
          You replied to a post about using the API to list commands, but if you're trying to login to the iOS app or the PWA at https://app.triggercmd.com, maybe you need a Pair Code instead of the token? If so you can get that by clicking your name in the upper-right, and clicking Pair like this:
