    Run a command on a remote computer from a Streamdeck button
    Instructions
      This is the easiest way to have a Streamdeck button run a command on a remote computer:
      • Create a Website button
      • Check the "GET request in background" checkbox
      • Copy/Paste the bookmark URL for the command into the URL.
      Every trigger has a red Bookmark button. Click that to get the bookmark link.
      If you rename the trigger, it will invalidate the bookmark URL and you'll have to copy/paste it again even if you rename it back to the original name. To avoid that, you could use a URL with this format instead of the bookmark URL:
      https://www.triggercmd.com/api/run/triggerSave?computer=(your computer name)&trigger=calculator&token=(token)
      You can get the token from the Instructions page, or in your user profile page.
      EDIT: Now you can use the official TRIGGERcmd Streamdeck plug-in.
