    Posted URL not working (with an Apple iPad)
    • A
      aaaaa12345
      Hi,
      I guess the restriction is with this forum software (or the iOS Chrome browser?)
      Once I post a 'commented' link like this:
      vmAPIRun() - The Announcer (Alexa/Google Ass. TTS)
      …it won't work/resolve if clicked on an iPad.
      Unfortunately it's not possible to fix this link if you've realized it too late, bc the forum restricts the editing of your own posting/thread (even if no one has replied meanwhile) to a few minutes after you saved it for the first time. πŸ™„
      Well, it might be possible to use a raw 'uncommented' link instead?
      Let's try: https://www.autohotkey.com/boards/viewtopic.php?f=6&t=106441
      Nope, also not working. At least someone is able to c&p it πŸ‘©β€πŸ’»
      Question: is there a fix for this iPad vs forum-link behavior?
      Workaround: if you're tabbing the link and select "open in a new Tab" the link will get executed correctly. πŸ‘
      HTH
        Russ @aaaaa12345
        @aaaaa12345, I've looked through the admin options and I haven't been able to find a setting to allow people to edit their posts for a longer period. I'll look again and maybe search the nodebb docs.
        EDIT: Nevermind, I must have been blind before. It's called "Number of seconds a post remains editable (set to 0 to disable)." It was set to 30 minutes. I disabled it so you can edit your own posts without limits. Sorry I didn't see that sooner.
        • A
          aaaaa12345 @Russ
          Thank you so much! You made my day <firework emoticon>
