    T. C. M. D.
    2 Posts 2 Posters 750 Views 1 Watching
    • A Offline
      aaaaa12345
      Hi Russell,
      is there a chance that you add "T. C. M. D." (Invocation Name) so we can call Alexa/Google alternatively using that keyword instead of "Trigger C. M. D." (well, nowadays I’m calling it with the even longer "Trigger Command" and it's starting fine *sigh*)?
      Rgds,
      Bo
        Russ @aaaaa12345
        @aaaaa12345, if I add a 3rd version of the non-Smart Home skill, I think I'll see if TC is available.
        I'm curious, why are you using the old TRIGGERcmd and Trigger Command skills? Is it for the voice reply capability?
        I generally encourage people to use the TRIGGERcmd Smart Home skill because it matches your words to your command triggers much better. I also think "turn on calculator" is easier to say than "ask trigger command to run calculator."
        Also, fyi, Google is discontinuing conversational actions (Google calls it an action instead of a skill). So after June 13, 2023, I expect the Google version of the TRIGGERcmd and Trigger Command actions to go away, and you'll have to use the TRIGGERcmd Smart Home action.
