    NO APARECE POP UP PARA PONER TOKEN
    2 Posts 2 Posters 480 Views 1 Watching
    • Paola CastilloP Offline
      Paola Castillo
      Hola, descargué e instalé el programa, pero nunca me apareció el pop up donde se pone el token, y no he podido vincular mi computador, de que otra manera puedo hacer ese proceso para poder vincular mi computador?.
        Russ @Paola Castillo
        @paola-castillo, I used Google Translate to translate what you wrote as:
        "Hello, I downloaded and installed the program, but the pop up where the token is put never appeared, and I have not been able to link my computer, how else can I do this process to be able to link my computer?"
        Assuming you're running Windows, you could run this command to run the agent in text mode in a cmd window with this command:
        node %LOCALAPPDATA%\TRIGGERcmdAgent\app-1.0.25\resources\app\src\agent.js --console
        You'll need to install Node JS first.
