    Help Me With KeyBoard Control
    11 Posts 2 Posters 3.1k Views 1 Watching
    • P2PP Offline
      P2P
      Hello im new and just want some action like press a button when i say something .
      I don't know if i can do this without script i want something like press 12 to save my game saying save game
      help me thanx a lot
      • RussR Online
        Russ @P2P
        @p2p, cool idea. This command should work:
        nircmd sendkeypress F12
        That assumes you meant press the F12 key?
        You'll need to install nircmd first.
        P2PP 1 Reply Last reply Reply Quote 0
        • P2PP Offline
          P2P @Russ
          @russ ok , i can do everything with keyboard touch or gamepad ?
          I play emulation and would like to make some shortcut with my voice... i préfer so first things is to install this ?
          And how can i do something like A button and B button at the same time or 2 other keyboard letters ?
          sorry my english bad
          • RussR Online
            Russ @P2P
            @p2p, I don't think nircmd can simulate a gamepad button, but it can simulate any keyboard press, so if you can control the game via keyboard, this should work.
            https://nircmd.nirsoft.net/sendkey.html
            https://nircmd.nirsoft.net/sendkeypress.html
            P2PP 2 Replies Last reply Reply Quote 0
            • P2PP Offline
              P2P @Russ
              @russ thanks for your help ^^ i will try some tips 😉
              • P2PP Offline
                P2P @Russ
                @russ hello, have you got any idea for how make the same thing with GAMEPAD buttons ?
                And have you got a list for the input ? for keyboard up its uparrow or just up ?
                • RussR Online
                  Russ @P2P
                  @p2p, this is the command to simulate pressing the up arrow button on your keyboard:
                  nircmd sendkeypress up
                  I don't know how to simulate gamepad buttons.
                  • P2PP Offline
                    P2P @Russ
                    @russ thanks i would try to make some special trigger
                    i explain you, i will make a turn on action with alexa for turn on my computer and on the log screen my alexa will be type my password and click ENTER ...
                    Does it possible ? i don't see how to write numbers for triggercmd can you help me to make a automatic password like "test123" and then enter for automatic log on session?
                    thanks
                    • RussR Online
                      Russ @P2P
                      @p2p, this command will type out test123 and press enter:
                      nircmd sendkeypress t e s t 1 2 3 enter
                      • P2PP Offline
                        P2P @Russ
                        @russ i must make it on background not foreground ? if i understand some other topic for use trigger command before log on service ?
                        • RussR Online
                          Russ @P2P
                          @p2p, you should make it a foreground command.
                          If you're trying to have Windows automatically logon during boot, you should use this method instead.
