    Issue when passing URL as parameter
    3 Posts 3 Posters 948 Views 1 Watching
    • C Offline
      Caio Kenup
      I have the very simple trigger that runs
      curl [params]
      So I can make GET requests to a local address remotely via the triggerCMD API. (If you think this is a work around using localtunnel or ngrok, it is exactly that)
      My triggerCMD API request looks like this
      https://www.triggercmd.com/api/run/triggerSave?computer=<MY_COMPUTER>&trigger=curl&token=<MY-TOKEN>&params="http://localhost:4040/webhook/id?par1=1&par2=b&par3=temp"
      The request only passes the first argument (par1 = 1), making me think the "&" character is improperly interpreted, despite being between quotes.
      The curl command runs correctly through the terminal
      curl "http://localhost:4040/webhook/id?par1=1&par2=b&par3=temp"
      passing all three arguments, again adding weight to the possibility that the API call is doing something to URL when passed as parameter.
      Any insight on how I could get this to work would be greatly appreciated!
      RussR Felipe FanchiniF 2 Replies Last reply Reply Quote 0
        Russ @Caio Kenup
        @caio-kenup, I'll mention this setting in your profile, but you may have already found it:
        I blocked those characters by default because they could be used to run arbitrary commands if parameters are enabled.
        A safer way to do what you're trying to do would be to use a script that takes a series of parameters like this:
        Linux/Mac bash script:
        set -x
        curl "http://localhost:4040/webhook/id?par1=$1&par2=$2&par3=$3"
        Make it executable with chmod +x ./script.sh
        Test it with: ./script.bat a b c
        Windows script:
        Test it with: script.bat a b c
        • Felipe FanchiniF Offline
          Felipe Fanchini @Caio Kenup
          @Caio-Kenup I solved this problem including ^ just before &. So, as an example, I changed
          start www.youtube.com/watch?v=dQw4w9WgXcQ&autoplay=1
          to
          start www.youtube.com/watch?v=dQw4w9WgXcQ^&autoplay=1
          I believe that it will works to everybody that has a URL with character "&"
