    Logging
    • L
      legtod2
      Logging on raspberry pi.
      Building a few triggercmds on my raspberry pi.
      Simple commands like shutdown and reboot work fine.
      If I want to launch foreground apps like the calculator "galculator" needs to launch a xterm or gnome app. The default user is pi and triggeragent runs as root.
      For debugging purposes of cmds how do I log and view the results.
      For example here is my calulator example.
      {"trigger":"Gnome Calculator","command":"galculator","ground":"foreground","voice":"calculator","allowParams": "false"},
      My assumption is that the command needs references to pi user and xterminal references to launch. But I cant see debug results to fix commands as they become more complex.
        Russ @legtod2
        @legtod2, to add logging I recommend running a script instead of the galculator command directly. You can add commands in your script that send the output to a log file, like this:
        echo Running galculator script >> /tmp/galculator.log
        As far as running GUI X windows apps as root that display in the Pi user's X windows environment, please look at this post.
        Basically you need these two things:
        In your bash script, add this command before it runs galculator:
        export DISPLAY=:0.0
        And in one of your bash shells running as the pi user, run:
        xhost +
        If you want the GUI app to run as pi instead of root, you can have your script run them with the su command like this:
        su pi -c galculator
        L 1 Reply Last reply Reply Quote 0
        • L
          legtod2 @Russ
          @russ that makes sense and easy to implement. Thanks for the advise.
          • L
            legtod2 @legtod2
            @legtod2 That works pretty well
            #!/bin/bash
            su - pi -c 'export DISPLAY=:0.0; galculator'
            {"trigger":"Gnome Calculator","command":"/home/pi/galc.sh","ground":"foregroun
            Now the next logical question is a close command.
            Should I have a 2nd script to perform a kill command or is there a slicker options of having a trigger command with option of open and close ?
            • L
              legtod2 @legtod2
              @legtod2 Ok so here's my open and close galculator that works
              {"trigger":"Open Calculator","command":"/home/pi/open_galc.sh","ground":"foreground","voice":"open calculator","allowParams": "false"},
              {"trigger":"Close Calculator","command":"/home/pi/close_galc.sh","ground":"foreground","voice":"close calculator","allowParams": "false"},
              cat open_galc.sh
              #!/bin/bash
              pi@raspberrypi:~ $ cat close_galc.sh
              #!/bin/bash
              su - pi -c 'export DISPLAY=:0.0; killall -9 galculator'
              • L
                legtod2 @legtod2
                @legtod2 Opps minor tweak on commands.json
                {"trigger":"Open Calculator","command":"/home/pi/open_galc.sh","ground":"foreground","voice":"calculator","allowParams": "false"},
                {"trigger":"Close Calculator","command":"/home/pi/close_galc.sh","ground":"foreground","voice":"exit","allowParams": "false"},
                I guess I need to learn about a command with options
                  Russ @legtod2
                  @legtod2, if you want to use the TRIGGERcmd Smart Home Alexa skill to turn on and turn off galculator, I'd recommend using the offCommand field like this:
                  {"trigger":"Open Calculator","command":"/home/pi/open_galc.sh","offCommand": "/home/pi/close_galc.sh","ground":"foreground","voice":"calculator","allowParams": "true"},
                  Notice I set "allowParams": "true" which is necessary to use offCommand, but because you're using offCommand, your /home/pi/open_galc.sh command won't receive the on parameter.
                  Alternatively you could use one shell script that expects the on or off parameter like I did here.
