    Google nest says:"TRIGGERcmd not registered on Google Home" when it is.
    2 Posts 2 Posters 792 Views
    • David JonesD Offline
      David Jones
      If I issue "Hey Google, ask TRIGGER c.m.d. to run fred on mumma."
      I get a reply TRIGGERcmd not registered on Google Home
      But on my phone on Home Control tab TRIGGERcmd Smart Home is listed under Linked Services. It actually says 22 devices. So the Voice Commands->Google Assistant don't work whereas Smart Home Voice Commands->Google Assistant do work.
      David Jones MVP
      Microsoft WinHEC/IoT/Embedded/App Development MVP
      https://github.com/djaus2
      https://mvp.microsoft.com/en-us/PublicProfile/5000301?
      @IOTMaestro
        Russ @David Jones
        @david-jones, if you enable the TRIGGERcmd Google Action it should work.
        You've only enabled the TRIGGERcmd Smart Home Google Action so far.
        I like the Smart Home action better personally because it creates on/off smart home switches for each of your commands, so Google Assistant just has to match your words to one of them when you say turn on X or turn off X. It has a much better chance of matching your words to your commands because it has a list of them ahead of time.
