    shutdown pc not working Plsss
    8 Posts 3 Posters 2.4k Views
    • Mevlüt BoraM Offline
      Mevlüt Bora
      Hi, I've been using trigger cmd for over 2 years and it's only for a single function. shutdown PC. And in the mornings, I open the pc with google assistant without trigger cmd, but for a few days, I noticed that the computer did not turn off, the time it was open was more than 4 days. The important thing for me is trigger cmd, I only use the closing feature, not the opening feature. but as I said, it has not shut down for 4 days and I tried many things, but the pc does not turn off at all. Even try to turn it off manually with the GUI, it still didn't turn it off. trigger cmd deleted all data but still works in the same state If there is no solution, I will format the computer and try. I tried every article but it still didn't work Thanks in advance.
      RussR tuicemenT 2 Replies Last reply Reply Quote 0
        Russ @Mevlüt Bora
        @mevlüt-bora, you wrote, "Even try to turn it off manually with the GUI, it still didn't turn it off." That information helps narrow it down.
        Are you using this command to shutdown?
        shutdown /s /t 60
        If so, can you try that in a cmd window like this?
        I wonder if that will give an error - like maybe it doesn't have access to shutdown.
        Mevlüt BoraM 1 Reply Last reply Reply Quote 0
        • tuicemenT Offline
          tuicemen @Mevlüt Bora
          @mevlüt-bora there are several reasons a windows PC will refuse to shut down A failed update is usually the reason. However here are a few things you can try. https://www.minitool.com/backup-tips/windows-10-wont-shut-down.html
          Mevlüt BoraM 1 Reply Last reply Reply Quote 1
            Mevlüt Bora @Russ
            @Russ Screenshot_1.png Thank you for your quick reply. But unfortunately that didn't work either
              Mevlüt Bora @tuicemen
              @tuicemen Thanks for the help but it didn't work 😞
              • tuicemenT Offline
                @mevlüt-bora, try solution# 8 from this link
                https://recoverit.wondershare.com/computer-problems/my-pc-wont-turn-off-or-shut-down.html
                  @tuicemen I tried a few fixes but no success. Thank you for your support. I will try formatting.
                  • tuicemenT Offline
                    @mevlüt-bora ,if you have the Windows 10 install disk you can do a system repair from it.
