    Log on issue
    • W
      willie8
      I can't seem to paste the token. I can copy it and it will paste into word but it won't paste into the agent sign on. The token is far too large to manually type in.
        Russ @willie8
        @willie8, what operating system are you using? Are you using CTRL-V to paste? Or I think it's Command-V on a mac.
        I think you might be trying to choose the Paste option from the Edit pulldown. I just tested that and I see it doesn't work. Thanks for pointing that out (assuming that menu option is what you're trying to use).
        EDIT 8/26/18: I fixed it.
