    My agent stopped working
    2 Posts 2 Posters 429 Views
    • Meet BhagwananiM Offline
      Meet Bhagwanani
      My agent stopped working, probably due to nodejs upgrade i did or something. Here is what i get no matter i tried, even reinstalling triggercmd couple of times. Current versions i have npm 8.1.3, node v17.1.0, nodejs v10.24.1. Pls. help.
      pi@raspberrypi:~ $ systemctl sratus tiggercmdagent
      ā— triggercmdagent.service - TRIGGERcmd Agent
      Active: failed (Result: exit-code) since Thu 2021-12-09 07:01:41 EST; 10h ago
      Process: 524 ExecStart=/usr/bin/env node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData (code=exited, status=2)
      Main PID: 524 (code=exited, status=2)
      Dec 09 07:01:41 raspberrypi systemd[1]: triggercmdagent.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
      Dec 09 07:01:41 raspberrypi systemd[1]: triggercmdagent.service: Failed with result 'exit-code'.
      Dec 09 07:01:41 raspberrypi systemd[1]: triggercmdagent.service: Service RestartSec=100ms expired, scheduling restart.
      Dec 09 07:01:41 raspberrypi systemd[1]: triggercmdagent.service: Scheduled restart job, restart counter is at 5.
      Dec 09 07:01:41 raspberrypi systemd[1]: Stopped TRIGGERcmd Agent.
      Dec 09 07:01:41 raspberrypi systemd[1]: triggercmdagent.service: Start request repeated too quickly.
        Russ @Meet Bhagwanani
        @meet-bhagwanani, I think you're right. The agent doesn't work with the latest versions of node js. I know it works with version 14, and I think it only works with early versions of 15. It's on my list to fix at some point, but for now, I hope you don't mind downgrading.
        EDIT: Correction - I just tried node version 16.13.1 and it worked.
        With your input, this post could be even better šŸ’—
