    Windows Agent Setup Fails
    2 Posts 2 Posters 1.3k Views 1 Watching
    • D Offline
      dave1223
      Downloaded the Trigger Agent Setup Executable today. Tried it on two different Windows 10 machines with all the latest updates and Java installed. Both machines working flawlessly for everything else. The Trigger Agent Setup Failed on both machines. There is a lengthy log.
        Russ @dave1223
        @dave1223, can you verify your Windows 10 is a 64bit version?
        If you search for "system" and open your System control panel, you should see this about half way down:
        System type:  64-bit Operating System, x64-based processor
        I ask because the normal agent doesn't work on 32bit windows.
