    Trigeercmdagent start, but it does not work
    5 Posts 2 Posters 1.2k Views 1 Watching
    • Wesley Galdino de FariasW Offline
      Hi,
      I've installed triggercmdagent, it is start without any erros, but it is not working.
      Bellow, the 'systemctl status triggercmdagent'
      Active: active (running) since Fri 2021-10-15 09:59:56 -03; 7s ago
      Main PID: 1996 (node)
      Tasks: 11 (limit: 4435)
      └─1996 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
      Oct 15 09:59:58 ubuntu env[1996]: Logging in with saved token to run background tasks.
      Oct 15 09:59:58 ubuntu env[1996]: Write backup completed.
      Oct 15 09:59:59 ubuntu env[1996]: |> Now connected to https://www.triggercmd.com.
      Oct 15 09:59:59 ubuntu env[1996]: ___/ For help, see: http://bit.ly/2q0QDpf
      Oct 15 09:59:59 ubuntu env[1996]: (using sails.io.js node SDK @v1.1.13)
      Oct 15 09:59:59 ubuntu env[1996]: Connected at: Fri Oct 15 2021 09:59:59 GMT-0300 (Brasilia Standard Time)
      Oct 15 09:59:59 ubuntu env[1996]: Initiated command removals
      Oct 15 09:59:59 ubuntu env[1996]: Initiated command adds
      Oct 15 09:59:59 ubuntu env[1996]: { message: 'Subscribed to 61697726d340a9001b5131be!' }
      I've noticed that, when I create a new command, in commands.json file and restart the service, it does not sync with the triggercmd site, but when I start the triggercmd with the --console option, just like that:
      node /usr/share/triggercmdagent/app/src/agent.js --console
      Everything works properly and the new command syncs with the site.
      What I must do to fix this?
      Tks.
        I've fixed the problem, but not in elegant way.
        I've changed triggercmdagent service systemd file located in: /etc/systemd/system/triggercmdagent.service
        From this:
        ExecStart=/usr/bin/env node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
        To this:
        ExecStart=/usr/bin/env node /usr/share/triggercmdagent/app/src/agent.js --console >/dev/null 2>/dev/null &
        From now on, it is working good.
        If someone has the reight solution for this problem, I'd like to know. Tks
          Russ @Wesley Galdino de Farias
          @Wesley-Galdino-de-Farias, I think I know what the problem was. I think your commands had "ground": "foreground" but you were running the background service which only cares about commands with "ground": "background".
          When you updated your /etc/systemd/system/triggercmdagent.service file you changed it to run in foreground mode.
            Thanks for your reply, and I'm sorry for the huge delay to reply you.
            You are totally right I was made this 'ground' mistake.
            Thanks
              @Wesley-Galdino-de-Farias, good. That's a common problem. I'm glad you figured it out.
