    Would this PHP code work?
    2 Posts 2 Posters 1.3k Views 1 Watching
    • C Offline
      ctaylor
      Hi,
      Been trying this PHP code and it won't work at all. Tried putting error reporting on and nothing is being thrown up.
      Am I doing anything wrong?
      <?php
      $ch = curl_init();
      curl_setopt($ch, CURLOPT_URL, "https://www.triggercmd.com/api/run/triggerSave");
      curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
      curl_setopt($ch, CURLOPT_POSTFIELDS, "{"computer":"FR-CCTV-ANALYSIS","trigger":"armed"}");
      curl_setopt($ch, CURLOPT_POST, 1);
      $headers = array();
      $headers[] = "Authorization: Bearer API Token removed";
      $headers[] = "Content-Type: application/x-www-form-urlencoded";
      curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
      $result = curl_exec($ch);
      if (curl_errno($ch)) {
      echo 'Error:' . curl_error($ch);
      curl_close ($ch);
      Thanks a lot if anyone can give some insight!
        Russ @ctaylor
        @ctaylor, you were so close! I made it work with a couple small tweaks. Here's my code that works.
        <?php
          $ch = curl_init();
          curl_setopt($ch, CURLOPT_POSTFIELDS, '{"computer":"DS","trigger":"calculator"}');
          $headers = array();
          $headers[] = "Authorization: Bearer (token from instructions page)";
          $headers[] = "Content-Type: application/json";
          curl_close ($ch);
        You'll see that I changed this line to use single quotes around the json object.
        And I changed this line to use application/json instead of application/x-www-form-urlencoded because you're passing a json object.
        In case you're curious, this is how I tested my test.php script:
        docker run -it --rm --name test-script -v d:\appdev\php:/myscript -w /myscript php:7.0-cli php test.php
        BTW, I'm curious what your application is.
