    Is it possible to use IFTTT to issue a command to multiple computers?
    6 Posts 3 Posters 3.5k Views 1 Watching
    • B Offline
      Bryan W
      I'm trying to make a command that will put both of my PCs into hibernation when I say, "Hey Google, turn off my computers." I've tried messing with the webhook a little, but I really don't know what I'm doing haha. I have an identical command set up on two PCs called "Hibernate" and I'm capable of hibernating them individually, but it would be nice if I could tell them both to hibernate with just a single command.
      Thanks for the help!
      (Here's a picture of something I've tried)
      https://gyazo.com/3f556b4ea17c748976a39b6ad55c111a
        Russ @Bryan W
        @bryan-w, the TRIGGERcmd API only allows one trigger per API call, and IFTTT only allows one thing in the That slot in the If This then That formula.
        If you want to multiple API calls at one time, I recommend using Stringify instead of IFTTT.
        This screenshot shows how you'd have a command run on two computers at once:
        TRIGGERcmd Stringify2
        Setup each Connect: Maker like this:
        TRIGGERcmd Stringify3
        Install it by searching for Stringify in the Home app:
        TRIGGERcmd Stringify1
        • B Offline
          Bryan W
          Thank you for the help, I'll try that out!
          • A Offline
            alon @Bryan W
            @bryan-w
            Another idea is for one of your triggers to trigger the other one using an API call for example using curl.
              Russ @alon
              @alon, good idea. I didn't think of that, but yea that's smart - you'd make a script with multiple curl commands that run other commands via TRIGGERcmd.
              https://www.triggercmd.com/forum/topic/25/use-curl-to-run-a-command-via-the-api
              • A Offline
                alon @Russ
                @russ 👍
