    GA replys "Done" or "Triggering All Lights Off on LivRmHTPC"
    2.1k
    • T
      Tim S
      I've tinkered with things a lot of ways to eventually get them working but this is stumping me. I'd really just like GA to say "done" in reply to a command. I had a bunch of my On commands stop working so I started investigating. I noticed in the GUI Command Editor was the new Voice Reply ability. For some reason I can't have individual replies to individual triggers and I'm fine with that. Just getting rid of the GA mouthful that comes as a response is great but it is consistently inconsistent. For example; I can get my "All Lights On" to trigger and GA consistently replies "Done" but my "All Lights Off" GA consistently replies "Triggering All Lights Off on LivRmHTPC" even though just like the other trigger they both have "Done" in the voice reply. And I don't know if you're aware of this and if it was on purpose but if I fill in a voice reply for a single trigger in the GUI Command Editor, it populates the rest of the Commands with the same Voice Reply automatically. I'm fine with that but why doesn't the GA reply work on all of them. If you look at my set up to investigate you really only need to looks at the current commands "All Lights Off" and "All Lights Please" they both have "Done" for a Voice Reply but "All Lights Off" is still giving me the GA reply "Triggering All Lights Off on LivRmHTPC" mouthful for a response. The worst part is it saying "on l-i-v-r-m-h-t-p-c" That's part alone is like hearing a 10 word response right there. I'd think if you can figure out why "All Lights Off" has GA response ignoring the "Voice Reply" field, it will tell me what I need to do with all my other commands where it's happening.
      Also btw, I had everything working then around the time the "Voice Reply" field was added my "All Lights Please" stopped working as well as others. I'm sure you understand why my On is Please instead of On. When I first set things up I found things didn't like turning things "on on" some PC. Also when I first set this up I had in the GUI Command Editor Trigger field as "All light Please" and Voice field as "All Lights Please" and this worked consistently every time until around when the "Voice Reply" field was added. I went thru all my commands that stopped working and was able to keep the Trigger field unedited and just edit the Voice field to "All Lights" removing the "Please" from that field only. Right now all my triggers are working 😄 Just the Voice Reply is making no sense as to why it is consistently working for some and consistently not for others when they look like there is no reason to me on my end 🤔
      • T
        Tim S
        Great... Now my "All Lights Off" has GA reply "Done" So confusing. Dunno why that is working now when so many of my commands are still giving me the GA reply "Triggering _____ on LivRmHTPC"
        • T
          Tim S
          So after doing some editing it seems that there is a problem with the changes being completed permanently on the first attempt. I can edit and select save. I then check by opening the GUI Editor again and see that the Voice Reply seems to have been changed but when I return an hour or more later and open the GUI Command Editor the voice reply will be blank again. 🤔 It does appear that some of the changes are taking effect but only after repeatedly trying to change them they eventually become permanent and I don't know why it has to be done more than once. I suppose if I keep at it they will all eventually change permanently but I don't know why I just can't change one, select save once, and be done with it. This is really frustrating.
            Russ @Tim S
            @tim-s, Thanks for letting me know. I found the bug and fixed it. Please update your agent.
            Thanks for telling me and sorry I didn't catch that in testing.
            T 1 Reply Last reply Reply Quote 0
            • T
              Tim S @Russ
              Awesome! Excellent work! Came home and activated Update Agent on server. Haven't spent much time with it but individual responses for individual commands is now working perfect it seems and when edited it seems to save the Voice Reply edits the first try. You don't mess around and get right on fixing stuff! Thanks!
