    I need to be able to pass '&' in a URL but this is disallowed?
    • Irfan KhanI
      Irfan Khan
      I need a trigger that launches a browser and a prefilled URL in jotform. this requires me to be able to send a '&' in the URL to add in additional prefilled fields. this is not allowed in TriggerCMD. is there a work around?
        Russ @Irfan Khan
        @Irfan-Khan, I originally blocked these characters as a security feature because they could be used to execute an an arbitrary command as part of the parameter.
        I'll add a toggle on the profile page to allow those characters in parameters. That way they're blocked by default, but you'll be able take the risk and toggle them on.
        EDIT: @Irfan-Khan , it's done. Please give it a try. You should see this checkbox in your profile page now:
        • Irfan KhanI
          Irfan Khan
          Thank you! works perfectly now! saved me the hassle of passing it into AHK to bypass this. very much appreciated!
            Russ @Irfan Khan
            @Irfan-Khan, nice. Thanks for testing, and thanks for the original question. I figured it makes sense to block those characters in parameters by default, especially when you give someone a bookmark URL to run your command that allows parameters.
