    Triggercmd.com sees my computer but not my commands?
    1.8k
      A Former User
      Ive set up trigger CMD on my windows 10 PC and a number of commands which work great from the command editor GUI.
      However while the website GUI does recognise my computer it does not show any of my commands and I guess therefore google assistant cannot recognise any of them.
      I have installed the background service but not sure where I should go from here. Any ideas?
        Russ @A Former User
        @michael-hill, you could try a couple of things. You could right-click the TRIGGERcmd icon and click Quit, then re-run it.
        If that doesn't work, you could delete your computer from the web gui, then Quit and re-run it again. It should then prompt you for a token from the Instructions page again. Hopefully that re-creates your computer in your account with your foreground commands. If that works, then restart your TRIGGERcmd service so your background commands get created on the website.
          A Former User
          Thanks, the following didn't work but I reinstalled on a second computer which worked and then copied the original text triggers back to my first PC which now works so must be something wrong with the way the GUI triggers entered into the trigger file in the original instance.
