    Accessing TriggerCMD through a URL
    • D
      dacarle
      I have a local windows batch file that I want to be able to run using TriggerCMD, that ideally I would like to be able to run directly through an outside URL. I could use Zapier, however, there can be a delay of minutes with zapier and I am looking to have someone be able to enter a url to remotely execute a process on my end (using IFTT or some other way). Can this be done?
      Thanks
      David
        Russ @dacarle
        @dacarle, that's definitely possible. Have you tried using a "bookmark" url? You click the Bookmark button next to the command to generate it.
