    Background Daemon Install Errors
    1.2k
    • M
      Monty
      Running Linux Mint, I wanted to have everything ready to go when I booted, so assumed I needed to have the background daemon running. I checked with "systemctl status triggercmdagent" and got this msg:
      Active: failed (Result: start-limit-hit) since Wed 2021-06-16 13:44:27 MST; 7min ago
      Process: 1906 ExecStart=/usr/bin/env node /usr/lib/triggercmdagent/resources/app/src/daemon.js --run /root/.TRIGGERcmdData (code=exited, status=0/SUCCESS)
      Main PID: 1906 (code=exited, status=0/SUCCESS)
      Jun 16 13:44:27 main systemd[1]: triggercmdagent.service: Scheduled restart job, restart counter is at 5.
      Jun 16 13:44:27 main systemd[1]: Stopped TRIGGERcmd Agent.
      Jun 16 13:44:27 main systemd[1]: triggercmdagent.service: Start request repeated too quickly.
      Jun 16 13:44:27 main systemd[1]: triggercmdagent.service: Failed with result 'start-limit-hit'.
      Jun 16 13:44:27 main systemd[1]: Failed to start TRIGGERcmd Agent.
      I then assumed I needed to run "installdaemon.sh". That appeared to run and install ok, but now I have two "main" computers in my computer list. Doesn't look right, LoL.
      I am really just trying to get triggercmdagent ready and willing to roll when I boot the PC w/o heading to the CLI and messing around. Do I need to start over, or is this salvageable?
      Great program but it is taking me a bit to get my head wrapped around how it works!
      Thanks,
      Monty
        Russ @Monty
        @Monty, sorry for the delay. I had company tonight.
        I think you've installed the background agent to run as root, and use /root/.TRIGGERcmdData as its data directory. You could send me the debug.log from that directory and I might see a clue, but you could also probably fix it with these steps:
        • Delete the computer records from your account.
        • Switch user to root with: sudo su -
        • Delete the /root/.TRIGGERcmdData directory with: rm -rf /root/.TRIGGERcmdData
        • Run triggercmdagent and enter your token
        • Restart the triggercmdagent service with: systemctl restart triggercmdagent
        At that point you'll probably have a new computer record in your account, and you'll be able to run background commands by adding them to your /root/.TRIGGERcmdData/commands.json file. Just make sure you set ground = background because the triggercmdagent daemon is running in background mode.
        If you run triggercmdagent as your non-root user in X-Windows, it will create a second computer account associated with your /home/(user)/.TRIGGERcmdData directory.
        Also fyi, I didn't create a way to automatically start the agent in foreground mode on Linux. If you figure out a simple way to do that, let me know please.
        • M
          Monty
          Well, everything seems to be working! If something is missing, I haven't run across it yet, despite those error messages. I can boot my computer and when everything is done starting, I can say "Alexa, run Sling TV" and up it pops in a Chromium (Linux) window; which was what I wanted. I haven't tried to find things that don't work yet, as I am enjoying those that do!
          As to running automatically, I simply added a command in the Linux Mint "Startup Applications" list with a 25 second delay:
          triggercmdagent
          That puts an icon on my status panel. If I right click it, I have options for:
          TriggerCMD.com
          Background Service
                Start Background Service
                Remove Background Service
          Text Command Editor
          GUI Command Editor
          Quit
          I have not done anything with those two Background Service controls as things appear to be working as I want them to.
          Thanks for the great support!
          Monty
            Russ @Monty
            Awesome @Monty, I'm glad you got it working.
