    Need help for a few commands
    • Rohan SodavaramR
      Rohan Sodavaram
      i Need help for a few commands here is the code
      Shutdown in 1 minute
       "trigger": "Shutdown in 1 minute",
       "command": "shutdown /s /t 60",
       "ground": "foreground",
       "voice": "shut down"
      Lock my PC
        "trigger": "Lock my PC",
        "command": "rundll32.exe user32.dll, LockWorkStation",
        "voice": "lock"
      Please reply!
        Russ @Rohan Sodavaram
        @Rohan-Sodavaram, what's the problem you're trying to solve? Those commands look fine to me. Do those work for you if you click the Trigger button on the triggercmd.com website?
        Rohan SodavaramR 1 Reply Last reply Reply Quote 0
        • Rohan SodavaramR
          Rohan Sodavaram
          This post is deleted!
          • Rohan SodavaramR
            Rohan Sodavaram @Russ
            @Russ when i say to my google assistant it does not work!
              @Rohan-Sodavaram, I see. Do your commands work when you click the Trigger button on the triggercmd.com website?
              Also, did you link your account with this Google Assistant Action?
              After you do that, you should be able to say any of the sentences on this page to run your commands.
              • Rohan SodavaramR
                @Russ i did
                  @Rohan-Sodavaram,
                  Do your commands work when you click the green Trigger button on the triggercmd.com website?
