    Trigger cmd don't recognice comand
    • carlos sollaC
      carlos solla
      Hello, every time I ask command to Google Assistant it only answers with "Say something like run calculator on laptop" and doesn't run the command. Any suggestions on what to do?
      Thank you.
        Russ @carlos solla
        @carlos-solla, I just replied to your Youtube post too.
        You're probably using the original "TRIGGERcmd" or "TRIGGER Command" skill, but you should switch to the newer "TRIGGERcmd Smart Home" skill here:
        https://www.amazon.com/VanderMey-Consulting-LLC-TRIGGERcmd-Smart/dp/B07P1MMFRP
        It recognizes your words a lot better because Alexa will already have a list of your commands. It creates a smart home device that simulates and on/off switch.
        This shows it working: https://www.youtube.com/watch?v=9Jm_s9sTZXw
        • carlos sollaC
          carlos solla
          The problem is a don't have alexa, I have google assistant
            Russ @carlos solla
            @carlos-solla, I'm sorry, I didn't notice that. The same goes for Google Assistant though - there are 3 google assistant actions:
            • TRIGGERcmd
            • TRIGGER Command
            • TRIGGERcmd Smart Home <- this is the one I recommend
            I think you're using either TRIGGERcmd or TRIGGER Command, but the best one is TRIGGERcmd Smart Home.
