    I can't open a server of mine which is a .bat file
    • username hereU
      username here
      • XanderX
        Xander @username here
        @username-here Without seeing any of the actual batch file, I'd guess that you need to include the path to the .exe in the command. If "srcds.exe" isn't part of the Windows path variable, you need to specify exactly where it is to be found.
