    Google home don't wan't use my commands
    6 Posts 2 Posters 885 Views 1 Watching
    • Rafa B.L.R Offline
      Rafa B.L.
      I logged in trigger cmd from the Google home app successfully but just shows the Defaults commands ..tried to logout and log in again but the same happens.
      I connected trigger cmd successfully with Smartthings it shows the "sleep" command but when I use the "sleep" command in Smartthings nothing happens
      Any help?
        Russ @Rafa B.L.
        @Rafa-B-L, please make sure you're using the "TRIGGERcmd Smart Home" google assistant action, not the "TRIGGERcmd" or "TRIGGER command" actions.
        The Smart Home version will create a smart home device for each of your commands that have the voice field filled in, and you can run the commands by telling Google Assistant to turn them on. None of the google assistant actions or Alexa skills will work with commands that don't have the voice field filled in, so please keep that in mind.
        I looked at your account and I see that two of your commands don't have the voice field filled in, so that might be the problem.
        Rafa B.L.R 1 Reply Last reply Reply Quote 1
          Rafa B.L. @Russ
          Thanks for the quick response @Russ reconnecting the account like 5 times fixed the issue and the commands showed up.
          PD: I'm wondering how to input "cntrl+S" thru the windows cmd? I'm trying to save changes till put my pc to sleep
          Thanks again!
            Russ @Rafa B.L.
            @Rafa-B-L, there are a few ways to do that. I think I'd use nircmd's sendkeypress feature.
            nircmd sendkeypress ctrl+s
            Rafa B.L.R 1 Reply Last reply Reply Quote 0
              Rafa B.L. @Russ
              thanks @Russ ill dig into it... im glad for the service/support your giving ill subscribe to triggercmd as a essential part of my smart home 👍
                Russ @Rafa B.L.
                @Rafa-B-L, awesome. Thank you!
