    Aplicación de Alexa, no detecta dispositivos.
    • Iván EspíndolaI
      Iván Espíndola
      Buen día. Tengo un problema, en el cual al instalar la skill de TriggerCMD en Alexa, esta no detecta los triggers como dispositivos, por lo cual no puedo crear rutinas. Si alguien sabe como solucionarlo, lo agradezco.
        Russ @Iván Espíndola
        Hello @Iván-Espíndola, google translated that as:
        "Good day. I have a problem, in which when I install the TriggerCMD skill in Alexa, it does not detect the triggers as devices, so I cannot create routines. If anyone knows how to fix it, I appreciate it."
        The most common cause of that problem is you enabled the wrong Alexa skill. You want the TRIGGERcmd Smart Home Alexa skill.
        This is the spanish version.
        • Iván EspíndolaI
          Iván Espíndola
          Hello! Thanks you very much. You are a genius! If you need some kind of help with a spanish translation or something like that, here I am. Best regards
            @Iván-Espíndola, thank you. If you see any incorrect spanish text on the website or on the Alexa skill description, please tell me how I could correct it.
