    Add a command with a variable to play music
    2 Posts 2 Posters 1.2k Views 1 Watching
    • F Offline
      favancini
      Hello,
      I use TRIGGERCMD on a pc with Ubuntu 20.04.
      I want to use it to play my music.
      I would like to know if it is possible to add a variable to a command like this :
      "Hey Google, say to TRIGGERCMD to play the album "X""
      Thank you per advance for your help.
        Russ @favancini
        @favancini, with the original TRIGGERcmd or TRIGGER command google assistant action, the format of the voice commands are like this: "Hey Google, ask TRIGGERcmd (or TRIGGER command) to run X with parameter Y"
        So you could say something like this:
        "Hey Google, ask TRIGGERcmd to run album with parameter X." Where X is the name of your playlist.
        Your command could run a script that runs your Mp3 player with X as your playlist parameter.
