    Shutdown command restarts the computer
    • S
      skainet
      Any idea why the shoutdown command does restart the computer instead of shuting it down?:
      This are the parameter for the command:
      Command: shutdown /r /t 2
      Ground: background
      Thanks
        Russ @skainet
        @skainet,
        If you want to shut the computer down instead of reboot, replace /r with /s.
        If you type shutdown /?, you'll see all of the shutdown command's parameters.
        Usage: shutdown [/i | /l | /s | /sg | /r | /g | /a | /p | /h | /e | /o] [/hybrid] [/soft] [/fw] [/f]
            [/m \\computer][/t xxx][/d [p|u:]xx:yy [/c "comment"]]
            No args    Display help. This is the same as typing /?.
            /?         Display help. This is the same as not typing any options.
            /i         Display the graphical user interface (GUI).
                       This must be the first option.
            /l         Log off. This cannot be used with /m or /d options.
            /s         Shutdown the computer.
            /sg        Shutdown the computer. On the next boot, if Automatic Restart Sign-On
                       is enabled, automatically sign in and lock last interactive user.
                       After sign in, restart any registered applications.
            /r         Full shutdown and restart the computer.
            /g         Full shutdown and restart the computer. After the system is rebooted,
                       if Automatic Restart Sign-On is enabled, automatically sign in and
            /a         Abort a system shutdown.
                       This can only be used during the time-out period.
                       Combine with /fw to clear any pending boots to firmware.
            /p         Turn off the local computer with no time-out or warning.
                       Can be used with /d and /f options.
            /h         Hibernate the local computer.
                       Can be used with the /f option.
            /hybrid    Performs a shutdown of the computer and prepares it for fast startup.
                       Must be used with /s option.
            /fw        Combine with a shutdown option to cause the next boot to go to the
                       firmware user interface.
            /e         Document the reason for an unexpected shutdown of a computer.
            /o         Go to the advanced boot options menu and restart the computer.
                       Must be used with /r option.
            /m \\computer Specify the target computer.
            /t xxx     Set the time-out period before shutdown to xxx seconds.
                       The valid range is 0-315360000 (10 years), with a default of 30.
                       If the timeout period is greater than 0, the /f parameter is
                       implied.
            /c "comment" Comment on the reason for the restart or shutdown.
                       Maximum of 512 characters allowed.
            /f         Force running applications to close without forewarning users.
                       The /f parameter is implied when a value greater than 0 is
                       specified for the /t parameter.
            /d [p|u:]xx:yy  Provide the reason for the restart or shutdown.
                       p indicates that the restart or shutdown is planned.
                       u indicates that the reason is user defined.
                       If neither p nor u is specified the restart or shutdown is
                       unplanned.
                       xx is the major reason number (positive integer less than 256).
                       yy is the minor reason number (positive integer less than 65536).
