    Trigger a uipath robot
    • C
      clarkzara
      Hello, im quite new and exploring the possibility of executing a command from command prompt using triggercmd. Basically my objective is to be able to run an application uipath that will be triggered using a command line....please refer to this documentation https://docs.uipath.com/robot/docs/arguments-description.
      I was wondering if i can do the same yung trigger cmd? my goal is to run triggercmd from power automate to execute the application of uipath robot.
        Russ @clarkzara
        @clarkzara, you definately could do that. Please tell me what you've tried.
        It looks like you could create a command with this format:
        UiRobot.exe execute [--process <Package_ID> | --file <File_Path>] [--folder <Orchestrator_Folder_ID>] [--input <Input_Parameters>]
        You might need to specify the full path to the UiRobot.exe file though. Like if it's in your c:\tools folder, you'd make your command: c:\tools\UiRobot.exe execute ....
        • C
          clarkzara
          Hello russ, i was able to make it work by creating a batch file, then trigger the execution of the batch via triggercmd. Initially tried to type it directly from the command but i can't make it work. I will try again later.
          Btw, another clarification, though i was able to add my local computer, i tried to install triggercmd in our virtual machine(on-premise), i can't seem to login using the token to add the VM as another computer. Is there a specific requirement whenever it is installed in a vm enviroment? Since the VM is using proxy to connect to the internet, would that prevent trigger from logging in?
            Russ @clarkzara
            @clarkzara, I'm glad you got it working.
            There's no problem installing the agent on a VM - I've done it many times.
            Connecting through a proxy is a problem though. I've tried to add support for a proxy server, but so far I haven't had much luck.
