    Null computer when running background task
    3 Posts 2 Posters 732 Views 1 Watching
    • J Offline
      jesgomp
      Hi, I am running on OSMC with a raspberry pi 3b+, and if I execute fom the terminal triggercmdagent, it all works properly as expected. It connects with a computer.
      The output is the following.
      Daemon install: false
      Logging in with saved token.
      Checking if the 845412155412 computer exists.
      Tokenfile: /home/osmc/.TRIGGERcmdData/token.tkn
      ComputerIDfile: /home/osmc/.TRIGGERcmdData/computerid.cfg
      Write backup completed.
        |>    Now connected to https://www.triggercmd.com.
              (using sails.io.js node SDK @v1.1.13)
               Connected at: Sat Oct 31 2020 19:51:34 GMT+0100 (Central European Standard Time)
      Initiated command removals
      Initiated command adds
      { message: 'Subscribed to dsgf9gsrherhreb1d52!' }
      But when I try to install the triggercmdagent daemon so it runs during boot with
      sudo /usr/share/triggercmdagent/app/src/installdaemon.sh
      the output is the next
      osmc@salon:/usr$ sudo /usr/share/triggercmdagent/app/src/installdaemon.sh
      Daemon install: true
      Checking if the null computer exists.
      This computer was deleted from your account.  Login to recreate it.
      * triggercmdagent.service - TRIGGERcmd Agent
         Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; vendor preset: enable
         Active: active (running) since Sat 2020-10-31 19:57:36 CET; 655ms ago
       Main PID: 1371 (node)
         Memory: 2.6M
                 `-1371 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdDat
      Oct 31 19:57:36 salon systemd[1]: Started TRIGGERcmd Agent.
      The json file is the next:
        {"trigger":"Gnome Editor","command":"gedit","ground":"foreground","voice":"edit","allowParams": "false"},
        {"trigger":"apagar","command":"shutdown -h now","ground":"background","voice":"apagar","allowParams": "false"},
        {"trigger":"apagardos","command":"shutdown -h now","ground":"foreground","voice":"apagardos","allowParams": "false"},
        {"trigger":"apt update","command":"apt-get -y update","ground":"background","voice":"update","allowParams": "false"}
      I do not understand why it does not get the computer, from the same file ComputerIDfile: /home/osmc/.TRIGGERcmdData/computerid.cfg, and how to fix it.
      I would really appreciate some help,
        Russ @jesgomp
        @jesgomp, on the Raspberry Pi, people generally install the agent with the root user, but you can make it work with your osmc user.
        Please edit your /etc/systemd/system/triggercmdagent.service file, and change that /root/.TRIGGERcmdData path to /home/osmc/.TRIGGERcmdData
        [Unit]
        Description=TRIGGERcmd Agent
        [Service]
        Type=simple
        ExecStart=/usr/bin/env node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
        User=root
        Restart=always
        [Install]
        WantedBy=default.target
        Then restart the agent with this command:
        systemctl restart triggercmdagent
        The agent will still run as root, but it should use your .TRIGGERcmdData folder in your osmc user's home folder.
        • J Offline
          jesgomp
          Thanks for your quick response, now it works fine
