    How to use IFTTT with TRIGGERcmd
    25 Posts 9 Posters 34.0k Views 2 Watching
    • D Offline
      delkem
      This works great when I create a normal IFTTT. I'm having trouble making it work when the IFTTT is created on the platform for private apps with a maker account. with this, you can make multiple steps or "that's" (think IFTTTTTTTTTT). Even if I just create one "that" in the private app, I get an "action failed" on the webhook with triggercmd.. "unable to make web request. Your server returned a 401"
      any ideas or is this an issue with IFTTT?
        Russ @delkem
        @delkem, I'll give it a try. It should work the same way.
        Method: POST
        Content type: x-www-form-urlencoded
        Body: token=(your token)
        One problem I've had before was I had a space in the body field that I didn't notice. That could cause that error.
        • D Offline
          delkem
          @Russ Thank You!!! yes, it was a space at the end of the token
            Russ @delkem
            @delkem, awesome! I'm glad that was it.
            • T Offline
              triggercmddm
              Am super-lovin' this 🙂 🙂
              However, and trying to configure an IFTTT Button Widget to kick-off a webhook to my PC (PC name R1) to run the Reboot in 10 seconds command, but keep getting 401 errors - please help.
              Am at the webhooks config page in IFTTT and entering the following:
              URL: https://www.triggercmd.com/api/IFTTT?trigger=reboot&computer=R1
              METHOD: POST
              CONTENT TYPE: x-www-form-urlencoded
              BODY: token=XYZ&params=russ.txt
              <obviously <XYZ> is my token 😉
              What am I doing wrong please ?
              Thanks so much,
              Dan
              • T Offline
                triggercmddm
                oops - that was for @Russ
                  Russ @triggercmddm
                  FYI, for anyone reading, @triggercmddm got it working. He needed to change the trigger name from 'reboot' to 'Reboot in 10 seconds' and he needed to remove '&params=russ.txt' from the body.
                  URL: https://www.triggercmd.com/api/IFTTT?trigger=Reboot in 10 seconds&computer=R1
                  BODY: token=XYZ
                  • T Offline
                    triggercmddm
                    ...so just for the record and to complete the loop.
                    @Russ just IM'd me and resolved the issue.
                    Amazing service and phenomenal customer journey 🙂
                    In brief, to reboot/restart your Windows 10 PC from an iOS Home Screen button click, do the following:
                    1. Install TriggerCMD Agent
                    2. Sign up/in to IFTTT
                    3. For the If bit: select Button Widget
                    4. For the Then bit: select webhooks and enter the following:
                      i. URL: https://www.triggercmd.com/api/IFTTT?trigger=Reboot in 10 seconds&computer=R1
                      ii. METHOD: POST
                      iii. CONTENT TYPE: x-www-form-urlencoded
                      iv. BODY: token=XYZ
                    Notes:
                    There are spaces in "Reboot in 10 seconds"
                    My computer name is "R1"
                    To add the button widget to your iOS home screen:
                    1. Tap the share icon (square with the up arrow)
                    2. Tap "Add to Home Screen"
                    3. Tap "Add"
                    4. Enjoy 🙂
                    • R Offline
                      rpondevie
                      I know this is an old post, but I wanted to share what I intent to do in order to illustrate what can be done with a very practical example.
                      I have a set of surveillance cameras. Some are indoor, some are outside. My associated software is iSpy. I also have a security system that only allows to get notifications via emails, as the Cie has its own proprietary surveillance system, at a different cost than mine (^_^). I want shut down the indoor and backyard cameras when I am in house, and turn them back on when I leave, or sleep, using the notification eMail. So, I plan on…
                       Create 2 tasks conditions in IFTTT, for “Off” & “On”.
                       Use <if><gmail> with proper filter on sender and subject), using respectively the words”Disarmed” & “Armed”.
                       Use your method to trigger a batch commands to iSpy, that may look like this:
                      URL: https://www.triggercmd.com/api/IFTTT?trigger=run ispy.exe "recordstop.alarmset"&computer=MyPC
                      ... where alarmset is the set of cameras to stop in this case.
                      I will keep you posted of the outcome.
                        Russ @rpondevie
                        @rpondevie, good luck. That's a cool project. I suggest you make your IFTTT URL something like this:
                        https://www.triggercmd.com/api/IFTTT?trigger=ispy&computer=MyPC&params=recordstop.alarmset
                        Then make a command with these values:
                        • Trigger = ispy
                        • Command = c:\program files\ispy\ispy.exe (probably a different path)
                        • Allow Parameters = true
                        • S Offline
                          spotandjake 100
                          @Russ how would I run it with multiple parameters I am trying to make a program where it moves the mouse with powershell when I run from the triggercmd website with parameters it run but when I run it like that my parameters do not pass threw only one does
                           https://www.triggercmd.com/api/IFTTT?trigger=mouse&computer=LAPTOP-M0RN3NEB&params={{TextField}},{{NumberField}}
                            Russ @spotandjake 100
                            @spotandjake-100, you can pass multiple parameters by separating them with a space, or a %20, so like this:
                             https://www.triggercmd.com/api/IFTTT?trigger=mouse&computer=LAPTOP-M0RN3NEB&params={{TextField}}%20{{NumberField}}
                              does the IFTTT webhook method work with a free account or only with subscription?
                              I tested with this comment without succes
                              https://www.triggercmd.com/api/IFTTT?trigger=Notepad&computer=PC
                              method = POST
                              Content-Type: application/x-www-form-urlencoded
                              with PC being the name of my computer as registered in my profile.
                                @koen-van-lent, it should work with a free account too, but only 1 per minute of course.
                                Do you have token=(your token from Instructions page) in the body?
                                • Mittal MakwanaM Offline
                                  Mittal Makwana
                                  Yuppie, this works so well thank you for the article. I did a simple google assistace IFTTT applet to put my mac to sleep.
                                    Russ @Mittal Makwana
                                    @Mittal-Makwana, nice, what command does that?
