    False warnings that trigger did not work
    3 Posts 2 Posters 194 Views 1 Watching
    • hlombardH Offline
      hlombard
      Commands triggered through your MCP connector (sender "MCP run_command") run and the agent logs "Reported: Command Ran", but we still get "your TRIGGERcmd agent doesn't seem to be connected" emails for every run.
      Please apply the same fix you made for Home Assistant triggers.
        Russ @hlombard
        @hlombard thank you for reporting it. I'm looking into it now.
        I can't seem to reproduce the problem (yet).
        Can you tell me which MCP connector you're using? Is it the stdio one or the streamable http one?
        Can you send me a screenshot of runs list for a command that had the problem?
        You might want to uncheck this on your profile page for now if the emails are annoying you.
        hlombardH 1 Reply Last reply Reply Quote 0
        • hlombardH Offline
          hlombard @Russ
