    Trigger for standby (Alexa)
    • LokilatorL
      Lokilator
      hi,
      i test Triggercmd with two Trigger
      i need a trigger for Power & sleep
      All my attempts failed.
      i use alexa for WOL
      To be able to reactivate the PC from this mode
      I hope someone can help me
      br
        Russ @Lokilator
        @Lokilator, you could run a command to put the PC to sleep, but once it's sleeping, the computer can't run commands, so you can't wake it up from the computer itself. You'd need to run a command on a second PC that would send the magic packet to wakeup the first PC that's sleeping. Is that clear?
        If you have 2 PC's, they could wake each other up as long as one of them is not sleeping at the time.
        LokilatorL 1 Reply Last reply Reply Quote 0
        • LokilatorL
          Lokilator @Russ
          this code work
          Command:rundll32.exe powrprof.dll,SetSuspendState Hibernate
            Russ @Lokilator
            @Lokilator nice, I've used the shutdown command in the past. I haven't seen that one.
