    Limit of triggers in the free option?
    4 Posts 2 Posters 894 Views 1 Watching
    • Pepe TopsP Offline
      Pepe Tops
      Hello everyone from Spain
      I've been updating the json file to add triggers for use with Alexa and IFTTT. After having written about 20, when I wanted to update, all but the initial 3 that I had have been deleted... What's the matter, that you can only create a few triggers? If so, are more added in the subscription? Thank you and best regards
        Russ @Pepe Tops
        @Pepe-Tops, no, you don't need a subscription to add more commands. You can have as many commands as you want. You might need to restart your agent if it stopped sync'ing.
        One thing to keep in mind - your agent is either running in foreground or background mode, and when it's in foreground mode it will only add/remove/run foreground commands, and vice-versa.
        If you installed the background agent, make sure your commands are background commands if you want it to use them.
        Pepe TopsP 1 Reply Last reply Reply Quote 0
          Pepe Tops @Russ
          @Russ OK, I will check and say you anything about...
          Best Regards
          PS
          it seams works, but if I use text editor (not gui) I must restart triggercmd agent.
            Russ @Pepe Tops
            @Pepe-Tops , good to know. I'll test and fix that if I can reproduce it.
